Old 11-29-2022, 07:15 AM   #5
It would be highly unusual if it were sent jetted rich. There could be a float bowl/inlet valve issue. You probably got a #40 pilot jet, and #120 main jet. These are probably OK at higher elevations. If you are below 1000 feet, those are on the lean side.
Red hot pipe is more likely to be a sign of lean jetting. Rejetting this carb is covered in the 2022 1/2 Templar X thread in this video and pics section.
Opening up the carb is on the post #7, and details are also on post #25.
I posted detailed needle shim instruction somewhere here. I need to track it down and add that to the 2022 1/2 thread. Ah, I found it. See the next post...
