12-03-2020, 09:53 AM | #1 |
Gas mileage for people that ride it hard?
I'm getting mid 50s with the stock speedometer (non-corrected speeds), a 130/80/17 rear tire, and a 13T countershaft sprocket. Fresh valve adjustment, plenty of power, running at 8000-9000 rpm on the highway and pretty much accelerating wide open from every stop when riding on backroads. I'm 275 lbs.
Does this sound about right? Charles. |
12-03-2020, 10:43 AM | #2 |
Pretty normal...given the 13T sprocket and WFO through the gears. The engine can take that treatment, no problem. You are probably giving up 5-6 mpg but that only means you go 20 fewer miles to a fillup. No big deal.
12-04-2020, 09:21 PM | #3 |
I was averaging 56 with the stock gearing, never WTO and all city driving so it sounds about right.
12-06-2020, 05:33 PM | #4 |
A 13T sprocket came with my bike when I bought it last month. Not sure I am going to use it yet I'm about 205 lbs. I think I'm going to check valves at 2500. I'm at 1900 now.
12-07-2020, 07:13 AM | #5 |
I get mid 50's when flogging it, but for my normal commute I usually get 65ish on mine (283 big bore kit) and 14k on it....does a little better with non ethanol gas
12-07-2020, 01:36 PM | #6 |
I never saw 50 MPG on mine, just under that. I did have a speedo corrector, and without that, the bike thinks you've gone farther than you actually have.
2016 RX3 2002 Honda CBR1100XX |
12-07-2020, 09:31 PM | #7 |
I just installed the speedo corrector yesterday, so I expect my mileage to drop considerably. I finally got the connectors from aliexpress and wired them into the SpeedoDRD, so I could just plug it in and not cut up my wiring harness.
Charles. |
06-13-2023, 02:44 AM | #8 |
I measured my fuel consumption in recent trip
Odometer distance: 591km GPS distance: 560km Fuel consumption (Pertamax 92 RON): 23.98L Bike was fully loaded with pillion (88kg + 65kg). Ridden quite hard but with absolute mechanical sympathy. Calculated fuel economy: 24.6 km/L (odometer) 23.3 km/L (GPS) |
06-13-2023, 12:43 PM | #9 |
Right on par with my roketa, mid 50s flogging thru the gears, 60 on the backroads, me weighing 290#, with a 13-38 (520 chain) on a 130/90-16 rear
Display Modes | |
