04-21-2024, 02:51 PM | #1711 |
I replaced the stock skid after a rather harsh impact with a rock bent it up into the motor. The stock skid is better than nothing but for 37 dollars this was a real upgrade.
Templar X Vitacci Clash 200 Beta 300rr GasGas TXT 125 |
04-23-2024, 05:43 PM | #1712 |
Front brake fluid reservoir cap removal
My front brake lever felt spongy and doesn't have a lot stopping power. I checked the reservoir sight glass and it's all clear (not sure if it's empty or over filled). I tried to remove the cap by loosing the 2 screws hold it down but they are super tight that I am about to strip them. Has anyone removed them before and what's the trick?
04-23-2024, 05:49 PM | #1713 | |
https://www.chinariders.net/showpost...29&postcount=9
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 04-24-2024 at 05:11 PM. |
04-23-2024, 05:56 PM | #1714 |
Awesome, thank you so much!
04-25-2024, 01:51 AM | #1715 | |
The 6th gear is great, and counter balancing is also a good thing. Personally, I ride mostly off road below 25mph, and I like the simpler engine. I just don't need a 6th gear.
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 04-25-2024 at 09:42 AM. |
04-25-2024, 09:28 AM | #1716 |
I went with the X instead of the M just because I wanted the 6th gear. I have a lot of dirt roads nearby but they all require at least a few miles of 55mph+ two lane highway so I wanted the extra gear.
If those highway runs weren't a factor I would have likely gone with the M for the extra backup of the kickstart in case my battery dies when I'm out camping in the boonies.
---------- 2023 Templar X 2009 Triumph Bonneville 1976 Yamaha DT175 1974 Honda MT125 |
05-03-2024, 03:04 PM | #1717 |
Anyone install an aftermarket kickstand after lowering their bikes? Most of the kickstand I've found on Amazon have a rear stud for the spring, while the Templar has the spring on the front.
I don't have a welder so I can't cut the stock kickstand. I did grind the stand a bit so it had more angle. It can hold the bike up for now now. I have to lean the bike way to the right to kick the stand down since it's too long. |
05-03-2024, 03:57 PM | #1718 |
You may just want to take it to a local welder or auto parts store with a machine shop to shorten it up. This is mild steel and easy to work with. Shouldn’t cost that much if your not in a rush. Just my thoughts…
05-07-2024, 09:20 AM | #1719 |
Hello everyone, where can I get parts for this engine, it has a knocking noise not in idle not accelerating but when engine is decelerating (rev up no noise let go gas tic-tic-tic)
I will start to investigate this noise furthermore but I am afraid to start needing replacing parts. |
05-07-2024, 09:30 AM | #1720 | |
Engine parts have limited availability, and many of them are not properly described in the vendor's listings with ambiguous engine names (often on aliexpress, etc). This engine is a Zongshen CB250F, specifically the 172FMM. Either designation might show up, but sometimes it shows CG engine. This is probably the most difficult issue with these bikes.
05-11-2024, 09:40 AM | #1721 |
In stock
The X is back in stock at PSM. Haven't checked the ebay or Amazon listings. My son just ordered one. We were going to get an M but not sure if/when they will be back in stock. Having the 6th gear is useful anyway.
Yes, the price went up, as suspected.
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 05-11-2024 at 10:55 AM. |
05-15-2024, 01:06 PM | #1722 |
If you don't have a balance shaft then it's the CB250F(ZS172FMM-3A) but if you do have the newer Templar X with a balance shaft then you have the PR250(ZS172FMM-5). Just saying this so fdurancol can figure out which 172 he has. |
05-18-2024, 08:42 AM | #1723 |
In stock
All three Templars are available right now- base, M, and X.
Prices have gone up as predicted by a couple hundred. X is still under, but just barely under $2000.
05-18-2024, 09:27 AM | #1724 |
Checked the PSM site this morning:
X - $1949 M - $1749 Base - $1599 Will be interested to see what the prices do throughout the year, I'm planning on picking up an M or Base in October when my son gets his motorcycle permit
05-19-2024, 08:31 AM | #1725 |
My son got his MCO and BOS yesterday, exactly one week after ordering. The crate is at the R&L terminal as of 4 days ago, scheduled for Tuesday delivery.
MCO does show "motorcycle", as requested.
