Old 10-08-2014, 02:37 AM   #16
Here are the malfunction codes for the Delphi MT05 ECM, as retrieved from the service manual.
These codes match the OBDII codes shown at the following website.
http://www.troublecodes.net/OBD2/Pcodes/
Old 10-08-2014, 03:12 AM   #17
Here is the Delphi MT05 wiring diagram for a 2-cylinder engine, taken from the service manual.
Old 10-08-2014, 03:19 AM   #18
Here is the connector pin information for the Delphi MT05 ECM.
Neither connector appears to fit the OBD2 scanner connector, which is shown below.
The OBD2 pin connections are described in the following link.
http://www.obdii.com/connector.html
The Delphi MT05 uses a 6-pin connector for diagnostics, as shown in the photograph below.
Therefore, it seems we will need to make an adapter to connect the appropriate pins of the OBD2 connector to the 6-pin Delphi connector. Likewise, we could also make an adapter to connect the OBD2 connector to one of the 18-pin connectors on the MT05 ECM itself.
Old 10-08-2014, 03:28 AM   #19
The Delphi fuel injectors have a heated tip to aid starting a cold engine with ethanol fuel.
Old 10-08-2014, 04:05 AM   #20
The Delphi MAP/MAT sensor employed by the Zongshen RX3 is specified in the Delphi service manual.
This item has several part numbers.
Delphi 12232201
Delphi AMW250118
Delphi 93333350
Delphi SMW250118
Old 10-08-2014, 10:33 AM   #21
Excellent! I'm pleased to hear that Delphi chose industry-standard existing codes.
Old 10-08-2014, 10:38 AM   #22
J1 and J2 are the connectors at the ECM, and are not designed for scanner interface, much like in your car. What we need to find is either the male version of the Delphi 6-pin, or just buy a male OBD2 connector and ditch the Delphi connector.
What we need to know is the pinout of the Delphi 6-pin.
Old 10-08-2014, 10:46 AM   #23
I agree that a heated injector would help with cold-starting (as you say), but I do not agree that ethanol will not ignite in liquid form (as the video implies).
Non-heated auto injector systems and even E85-specific carbs will still run without added heat.
The real benefit is easy, consistent starting in any temperature, and no need for an enrichment circuit or conventional choke.
Old 10-08-2014, 01:29 PM   #24
As always, thank you for you informed input, Weld.
Old 10-08-2014, 02:02 PM   #25
I believe the Delphi, 6-pin female is Delphi part #12052848. Here are just a few links to vendors for that part.
http://www.mouser.com/ProductDetail/...Q5ZRoCdwDw_wcB
http://www.electricalhub.com/delphi-...pack-connector
http://www.waytekwire.com/item/38210...-SERIES-6-PIN/
I believe the Delphi, 6-pin male connector is Delphi part #12124107. Here are a few links for that part.
http://www.waytekwire.com/item/38209...-SERIES-6-PIN/
http://www.mouser.com/ProductDetail/...jRDxoCi9fw_wcB
http://elcodis.com/parts/2024047/12124107.html
http://delphi.com/connectors/product...esults&start=0
Old 10-08-2014, 02:05 PM   #26
Perhaps the easiest solution is to buy an adapter harness, such as the one in the link below, and wire the appropriate Delphi plug on the other end.
http://www.ebay.com/itm/20-to-16-Pin..._Tools&vxp=mtr
Old 10-08-2014, 02:13 PM   #27
Here is some more information on OBD2 connector wiring.
http://www.bmwgm5.com/Peake_AB03.htm
http://www.obdtester.com/obd2_connector
http://www.change2e85.com/servlet/Detail?no=160
https://plxdevices.com/obd/
http://www.obdtester.com/obd2_protocols
http://clubroadster.net/vb_forum/74-...t-install.html
http://www.rberger.com/Car_Diagnosti...stic_Codes.php
Old 10-08-2014, 02:18 PM   #28
Someone was selling a Delphi Motor Scan KF90121 on ebay for $109.99, delivered. See the information at the bottom of the webpage.
http://www.ebay.com/itm/Delphi-Motor...78bdf1&vxp=mtr
Here are some photographs of the Delphi motor scan, and it's connectors.
Here are some other photographs of the scanner.
Old 10-08-2014, 02:25 PM   #29
Here's the wiring diagram for the scanner connector from page 70 of the Delphi service manual.
Old 10-09-2014, 12:55 AM   #30
Perhaps somebody already manufactures a Dephi 6-pin to OBDII adapter.
