Old 03-22-2016, 02:16 PM   #16
jbfla   jbfla is offline
Originally Posted by Eco Mouse View Post
Might be a good excuse to get an inspection camera.
http://www.harborfreight.com/high-re...der-60695.html
I have one, but it's at my shop in North Carolina. I was hoping to ride the RX3 there next month.
jb
2014 XT 250........
Old 03-22-2016, 02:19 PM   #17
Juanro   Juanro is offline
Juanro's Avatar
Perhaps a loose or broken cam chain tensioner? And the sound is the chain randomly slapping around? That's an easy check/fix
Old 03-22-2016, 02:22 PM   #18
I was thinking likewise.
I can't find anything in the service manual that even mentions the cam chain tensioner.
Do you know if it is an automatically adjusted tensioner, or if it has to be adjusted manually?
Awaiting a response from CSC as to what to do next.
jb
2014 XT 250........
Old 03-22-2016, 02:25 PM   #19
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
Oh great, is this the RX3's Doohickey? I'm all too familiar with that on 2 different KLRs.
Old 03-22-2016, 02:26 PM   #20
Juanro's Avatar
It's "automatic" (spring + ratchet), is that right there where you're sound probing
Old 03-22-2016, 02:30 PM   #21
Juanro's Avatar
Take a look at this picture from the AKT (colombian) bike
Old 03-22-2016, 02:32 PM   #22
Tiger12XC   Tiger12XC is offline
Tiger12XC's Avatar
jb
My Orange RX3 has a noisy top end also. My wifes White RX3 sounds like a sewing machine it makes me wonder if my riding style is contributing to the noisy valve train or its just the nature of the engines (I wring this baby out merging onto Texas freeways). Chain noise and clutch basket sound noisy on my Orange RX3 also. The White RX3 purrs like a kitten and they both have the same mileage give or take a few miles. I hope you get it figured out JB spring is here!
Old 03-22-2016, 02:56 PM   #23
Indeed, the NC250 engine has an automatic, cam chain tensioner (ACCT). Here are instructions for inspecting the ACCT, from the following thread.
http://www.chinariders.net/showthread.php?t=15545
First remove the center bolt to release the spring pressure.
Remove the spring and O-ring.
Remove the two screws at the base of the ACCT.
Caution:
After removing the ACCT, return the plunger to its initial position by pressing on the locking cam, and pushing the plunger to the base of the tensioner.
Old 03-22-2016, 02:58 PM   #24
Here are instructions for installing the ACCT, from the following thread.
http://www.chinariders.net/showthread.php?t=15546
Replace the Automatic Cam Chain Tensioner (ACCT)
Install the ACCT with the two screws at the base.
Install the spring and O-ring.
Install the center bolt to set the spring pressure.
Old 03-22-2016, 03:00 PM   #25
Tiger12XC's Avatar
That is the area where the chain tensioner is and in the video it did sound random like chain slapping it would be worth a shot at checking it out.
Old 03-22-2016, 03:05 PM   #26
Thanks for the photo, Juanro, Spud, and Tiger.
I removed the tensioner, and the spring, and the piston click mechanism seem to be working properly.
When I reinstalled the spring, I could hear (with the stethoscope) the piston clicking into place.
jb
2014 XT 250........
Old 03-22-2016, 03:08 PM   #27
jb
Did you retract the plunger, and lock it with the cam lock before you re-installed the ACCT?
Old 03-22-2016, 03:10 PM   #28
Jay In Milpitas's Avatar
Are you flopping around?
jb
One quick (and easy) thing you can do is to remove one of the cam window plugs and the crankshaft plug, then with your hex wrench, rotate the engine forward until you see one of the cam marks, then rotate the crank backwards ( it will be harder) and note how much or little the crank moves before the cam does. Repeat a few times until you are certain the chain is either tight or loose. If loose, then likely the tensioner or one of the shoes is needing attention.
Alternatively, you may be able to removed the tensioner assembly (carefully avoiding damaging the gasket) and check that it's parts are working as they should.
Note: just before posting this I see Spud has also chimed in.
Edit: I see you got here also, JB.
Old 03-22-2016, 03:16 PM   #29
Thanks, Spud.
Followed the directions.
However, I hope I didn't sign up for an engine disassembly when I purchased the RX3.
jb
2014 XT 250........
Old 03-23-2016, 08:12 AM   #30
CSaddict   CSaddict is offline
CSaddict's Avatar
Sent the video to friend that ran the service department at the local Yamaha/Suzuki/Can Am dealer and he said it sounds like a wrist pin or crank bearing issue.
Edit. listened again and now thinks rod bearing.
2016 CSC RX3 Ginger Edition
Check out my blog here:
https://www.facebook.com/My-CSC-Zong...0302595973417/
