Vibration
What have you all done about the vibes at 60mph?
Not a problem on mine, yours must be defective.
Oh, and mine hasn't passed 57. |
1 Attachment(s)
Popped the Hawks cherry today.
looks nice :) I went with black but red would have been my second choice
it will be less vibration |
vibration? i have two hawks, neither seems to vibrate to any more than nominal extent and as for what there is at higher speeds seems to me to be from the hardcore full knobby tires. Actually i'm quite interested in seeing the difference with my soon to arrive TT250 with the balanced motor and the more DP tires. And as for speed, get some miles on those bikes first. After 500 to 600 miles they really seem to come to life. 60 t0 65mph is no problem with my 16/45 gearing ,with a lot of throttle left. I expect to bust 70 without drama when i reach 1k miles on the engine,reset the valves, and switch to full synthetic in the case. (and keep that chain clean and lubed! The friction killing Dupont stuff from Walmart can easily get you a couple of mph over a dry/dirty chain).
Guess I'm just not used to a 250 single. My other ride is a Triumph Thunderbird.
I swear the vibes are less on my hawk after gapping the valves at aroung 800 miles. They were too tight. Not really sure if an engine with tight valves would vibrate more, maybe it is in my head but it sure seems smoother now with the valves set correctly.
Many Hawks reported with with tight valves, so I would check them asap. |
