TBR7 valve clearance screw replacement ❓️❓️❓️
What's good guys. I been having a really hard time trying to find a replacement for my TBR7 rocker arm adjuster screw. I was trying to adjust trying valve clearance like most people recommend and while I was tightening the screw snapped in half. I have very High Hopes that someone can help me find the right replacement for the screw. Pls and Thank You.
Check with CSC. The TT250 should use the same Tappet Adjuster screw.
Alrighty I'll try them options out. Thank You
