I called jp motorsports to see if they knew of anything compatible and they said nothing they know if is. So I will try the ninja 250 trick and super glue a thin sheet of plastic on the inside of the throttle tube where the cable goes against. This increases the diameter slightly which in turn means a faster cable pull, which in turn reduces the rotation that is required to go from closed to open.
sigh I wanted to ride a little more although I probably wouldnt be able to until tomorrow now its looking like a few days to a week :(
