I wouldn't even rent. I'd ask a neighbor to borrow theirs.
I wouldn't try to pull a mower with the 150...and CERTAINLY not with a CVT/auto. I wouldn't go any less than the 200's that are floating around, and then you'd have to find a HUGE sprocket. On my HiBird I'm currently running 15/38 gearing and, at idle, you couldn't pull the mower...there's no power at idle. You'd even have that issue with the CVT or auto.
If I had no other choice than to use my quad, then I would be looking a 90 tooth rear sprocket...and even then I would have to have it adapted because lord knows you can't find sprockets that bike in our bolt patterns.
Plus, for what it would cost to buy a quad to pull the mower he could hire someone to come and blade the entire property so that using a lawn tractor is feasible.
