basically, I was saying that my voltage tester didn't show a signal on the spark plug, but I have replaced the line going from my ignition coil to my spark plug cap. Also replaced the spark plug cap and new spark plug.
In other news I did the solenoid test with a screwdriver on the posts of the solenoid and the engine tried to turn over.
1. Does this mean my solenoid is bad?
2. Would it attempt to start when doing this solenoid test even if the key wasn't turned to the run position? (because it did)
3. I still don't know if the spark plug is going to spark until I can connect the battery without the starter turning over, is there a better way to do all this?
thanks again
