Originally Posted by Weldangrind
I scored well. Gnarly parts ( www.gnarlyparts.ca) has the front sprocket for $11, the rear for around $27 and a new RK 520 chain for $32. I also ordered a new countershaft seal and shifter seal from Precise Bearing; all of those parts should be in by Friday.
Today I picked up two cheap dual sport tires, a generic rear fender and a 6 volt gel cell battery for cheap. I'm also going to order a replacement speedometer cable on eBay as soon as the seller confirms compatibility.
I soaked the seat latch and steering lock in lube and worked them until they would operate smoothly. I also got the spare key re-cut to properly works those locks (no charge at the locksmith).
Looking forward to more shop time.
Indeed, you scored well on the sprockets and drive chain!
You made excellent progress today. Thanks for the update, Weld.
"Never argue with an idiot. He will drag you down to his level, and beat you with experience."
Mark Twain
Mods made to my Zongshen ZS200GY-2:
http://www.chinariders.net/showthread.php?t=6894
