Originally Posted by steveccanyon
Originally Posted by SpudRider
Incidentally, that's a nice looking bike. I like the plastic, exhaust, headlight, and skid plate. What model Lifan is that? Did the bike come equipped with hand guards, or did you add them?
its a 200 explore, i added the bash plate and hand gaurd, it look good but needs more grunt.
Another problem is the front forks when I brake the front pulls to the right a lot, going to have to change the suspension it's not enough for Laos...any ideas what will fit on it?
Pulls to the right....
That's not good.
Check the rear wheel alignment. You may need to measure with a string. The witness marks may not be reliable/symmetric.
I'd also check the front axle bolt(s) and loosen and retorque the triple tree bolts. Check for play/looseness in the steering stem bearings. Finally look for any cracks.
