engine shaking: inspect and tighten mounting bolts?
no air filter: no good, you should be able to get a piece of foam, oil it and stick it in.
tail light should be easy, when you take the seat off you ll find the connectors under the end of the seat (hopefully).
sounds like you got yourself the most sought after No1 chinese superbike
look after her and she ll look after you
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL
223 ZS + 2007 Zongshen LZX200G + DR400SM
