Originally Posted by Weldangrind
I bet it's the headlight plug. If you remove the plug from the headlight, you might be able to make the connectors a little tighter, maybe with a small screwdriver.
It would be easiest to install signals by buying a new wiring harness. If you could find a China dual sport harness for cheap, you could extract everything you need for signals, and then substitute signals that suit your chopper.
There are probably two plugs; one at the light (3 prong) and one at the harness. I had trouble with the harness one and eliminated it by connecting the wires before and after the plug. I soldered them to make sure the connections were good.
