Originally Posted by SpudRider
You won't have a problem if you are using two, LED turn signals. However, if you have four, LED turn signals, you need to do two things.
1) Get an LED flasher unit
2) Remove the turn signal indicator bulb, or install a diode kit in front of the indicator bulb.
I am heading out for the evening. However, if you have further questions, I will answer them later.
Awesome! I can get the flasher at work. Do you have any info on the diode kit? I want to weigh my options before I just yank the bulb.
