Old 05-21-2014, 01:17 AM   #15
pete   pete is offline
pete's Avatar
It has rubber bushes in the swing arm pivot... i will look at the honda brearings...
I am going to strip it down soon & move the swing arm pivot up 30mm which
is easy to do... make a new spacer tube , drill 2 holes & put the tube though
and weld it there.. I have looked at pics of a few of the higher prised pitbikes
they mount the arm higher up.. that will make the chain tighten instead of lossen
as the arm swings up..
I might also cut the frame just back from the steering head & add 50mm , 2" into
it..As I see there is a 2" longer version frame... longer frame would be better as caleb grows..
It also need a new shock... The spring seems to have compressed " to short for the shock now"
An't chinese bikes just so much fun....
PS.... also needs a steering stop that dosn't bend every time it's droped..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
