Originally Posted by katflap
A little bit of info.
Top box & large pannier inside measurements w = 38cm, L = 28cm, Depth including lid recess 19cm
Smaller pannier is the same but the depth is reduced to 8cm * for a good 50% of it.
(* I think 8cm is correct struggling to read my own hand writing)
Oil filter
100mm long (metal to metal) with a diameter of 30mm
One end at the centre seems to have a ball bearing and spring style pressure relief valve.
The other end has a glued rubber washer diameter of 25mm, thickness 2mm and hole in the centre of 8 or 9 mm.
Download - circuit diagram including EFI in English
https://mega.co.nz/#!40pADJjZ!1wOenhh9h9QCaSRghWwUlhx_MmcUInDCnSTmBts 4VQE
If your bikes do come with a retracting side stand it’s quite easy to modify if you want to. Im thinking of rigging up a switch and buzzer to let me know when it’s still down!
Thanks for taking the time to measure, and post the good information.
