Originally Posted by Jibberwobble
I've got to say that is indeed a wicked bike, really looks good. Glasto Tor is a nice walk and the gorge must be quite fun to ride
Yeah will have to take a ramble there when it gets a bit warmer.Im still in the early stages of trusting the bike so it will be a while before i dont have chicken stripes on the tyres! that said it was still fun to ride the gorge to help me gain my confidence.
Originally Posted by SpudRider
Katflap,
If you have time, and are so inclined, I would love to know the dimensions of the counter shaft (C/S) sprocket.
You can loosen the locking tab by tapping it lightly with a hammer and chisel/screwdriver. Just widen the tab enough to loosen the bolt. You might also need to loosen the rear axle to get enough slack in the drive chain to remove the C/S sprocket.
You are probably right ,the tabs on the lock washer should survive a few uses.
I could really do with the torque setting for the bolt before i start jumping up and down on a spanner inside a scafold pole.
I really dont want to screw any thing up at the moment ,ive got to ride it to work in the morning
Regarding the plastics --
the Black plastic seems to be all the same , quite flexible .As you have said the orange plastic is different and painted ,though the outer seems to have a Clear Lacquer on top.
The inside of the fork protector i have scrached with a screwdriver to reveal the black plastic underneath ( see arrow in picture )
