Old 05-08-2015, 01:35 AM   #3
Originally Posted by G19Tony View Post
Well, ok then. I'll be adding oil again tomorrow, but I believe I have around 1.5-1.7 in it now. If you dump all 55 ounces in, the oil will go above the fill line, correct?
Yes, the initial 55 ounces might fill the oil above the proper level in the sight glass. However, after you run the engine, and the oil is distributed throughout the nooks and crannies of the engine, the oil level will drop to the appropriate level in the sight glass.
