Originally Posted by SpudRider
Good for you. You are going to be very happy you replaced the stock fish oil in the forks with some legitimate, 10W fork oil.
Here is a link to the webpage containing the CSC maintenance tutorials. The RX3 Sticky Thread, located at the top of this forum, also contains a link to the CSC Tutorial page.
http://api.viglink.com/api/click?for...rial%20Webpage
Other than fork oil, the most important item you will need is a very thin, 14mm wrench! This wrench must fit between the coils of the spring so you can hold the nut at the top of the damping rod to unscrew the fork cap. Otherwise, you will not be able to remove the fork cap.
I strongly suggest you acquire a very thin, 14mm wrench before you start this job.
Is this a necessary step if all you are going to do is swap the oil??
