Welcome to the forum and China Bikes. The counter shaft is hardened, so the wear will be to the sprocket. You will replace the sprocket due to normal chain/sprocket wear before the slop at the counter shaft/sprocket becomes a problem. Chain lube or grease when assembled should slow the wear to the shaft/sprocket contact area. Enjoy.
2015 Hawk 250
1972 Honda CT70
Past
1982 GS1100L
1983 Honda ATC 185s 2ea.
1974 Puch 175mx
Reason: spelling
