Originally Posted by Weldangrind
You're going to need to re-jet to take away some power.
I suspect that 20 ft/lbs is a little high. Assuming it's around 5/16" and about Grade 5, the spec would be closer to 13.
Dang... I figured it was close to the fork clamp bolts.
Another thing I noticed when installing these studs is that they were smaller than the originals. You can see in the picture the larger hole where the original size wouldve fit. The sprocket has two sets of holes, so if I can find the correct size hopefully it'll stay together.
