Old 10-23-2016, 05:22 PM   #21
I changed the oil and adjusted the valves. The valves were tight with no gap. I went take a quick ride and noticed that it ran better. When I got back in took the carbrerator off and prep it for when I get the Jets in. I did the hacksaw method to slot the screws. Next I shim the needle with 2 washers and turned the idle mixture out 1 1/2 turns. Now it will start and Idle without choking it. Throttle response is so much better.
2020 Kawasaki Vulcan S
