Old 01-04-2017, 02:25 AM   #5
vickytulla   vickytulla is offline
vickytulla's Avatar
Originally Posted by Jay In Milpitas View Post
The RX3 with fuel injection is very sensitive to valve clearance. Be sure you have that adjusted correctly.
hello Jay, thanks for replying, I have just uncrated the bike and doing its running period, will do valves clearance on 300km mark, just 50kms more .
RX3 also have sprockets that are better for high speed. For trails most riders have changed to 13t front sprocket, and some have also changed the back sprocket to 46t from stock 44. Really makes the power feel better.
this make a lot of sense... I will be looking into this..
I can not help you about the speedometer, I don't look at mine.
You can make the fuel gauge read better by bending the arm for the float. You will find instructions somewhere here.
Good luck, enjoy your RX3!
yes i will do some stuff I see a lot shared by spudrider... (Y)
Prime RX3 from Pakistan
- Adventure Touring# RX3 - 2017
- Dirt Machine# FSE-450 - 2022
- Classic# Honda CD175 - 1977
- Daily Runner# 1992 - CG125 (engine swap CB250 Sleeper)
- Project#1 : 1995 - Honda C70 w/ 180cc engine swap
