No start
If you turn the key on...apply the brakes...the brake light should come on...the brake switch is a safety switch...check the wires on the brake mircoswitchfor power...make sure the fuse is good as well ...you can jump the solenoid and apply power right tothestarter... It should start & run...let us know after youdothis
ABIBABA ATV ETC
