Old 01-27-2017, 11:33 AM   #1
katflap   katflap is offline
katflap's Avatar
Is that iacv something you could remove to inspect/clean? Also could you swap a donor battery to see if it has any effect on the stall? I know your bat is showing good.
Something else I was thinking , do some bikes come withe duel fuel injectors? This way it doesn't rely on only one in the event of a missed pulse if that is the cause of the stall. Probably impractical for rx3 application. Just thinking aloud
Yes, the IACV can be cleaned though I think it is a delicate procedure, (I have it somewhere will try and find).
My description of the IACV steps graph was slightly inaccurate. The graph shows the "step" position that the Delphi ECU has requested and not the Actual "step" position that the IACV is at. Though normally this would be the same thing.
So if the IACV is malfunctioning it could be in a completely different "step" position.
I don't suspect a malfunction as it works perfectly at any other time.
The problem could be the ECU not requesting a big enough change in IACV steps, this will be down to the ECU mapping and could be changed with a map update.
I could try another battery though I think the low voltage as the idle drops down below idle speed it gets below the RPMs where the generator can offer any charge and the battery still trying to recover from cranking the bike at start, especially hard on batteries in cold weather.
I will try another battery when I get the chance and see if there is a difference.
Not heard of a duel injection for the same cylinder though the Delphi ECU is capable of controlling 2 injectors for a twin.
I hope that the ECU would flag a fault if the injector missed a pulse
Anyway, thanks BlackBike, all your comments are good food for thought
