Originally Posted by jbfla
However, since I don't have a permanent place to set it up, I find that I regularly pull out the tire irons, instead.
jb
Ah, it doesn't need to be bolted to the floor, JB, it only needs to be attached to something to stand on, either metal plate or plywood.
Metal plate you can weld some studs on or just drill & tap some holes.
A 3'x3' sheet of 3/4" plywood with either Tee nuts installed or some carriage bolts driven through will also suffice.
When not in use, disassemble & tuck them all away. Or if you plan ahead the same base can be used to mount a pedestal grinder, vise, or other shop thingy.
Jay, cheap-ass bastage.
