Clutches, pt two
OK, assuming we have made the cable run as smooth as possible, and that the cable adjustments have been done, but the clutch still drags, We'll have to take the clutch cover off, remove the spark plug, and roll the engine over on the starter motor. Pull the perfectly adjusted clutch lever all the way back to the handlebars. If the release plate (the one with the springs) wobbles with the clutch lever pulled tight to the 'bars, that will cause this problem. Now the problem is, are the screws holding the springs out of adjustment, or does it have a broken spring....You should be able to figure this situation out and rectify it....ARH
