Old 04-27-2017, 05:06 AM   #2
You must remove the two bolts from the intake manifold before you can remove the engine from the motorcycle. I suggest removing the MAP/T sensor from the intake maifold before you remove these two bolts.
Removing the MAP/T sensor makes it easier to access the two bolts. Also, while the MAP/T sensor is removed, you should clean it with Mass Airflow Sensor Cleaner. Cleaning this sensor periodically will improve engine performance.
http://www.autozone.com/miscellaneou...ner/36011_0_0/
