The Linhai is a gy6 style engine ,it is belt drive in that side case ,common engine in a scooter with a wheel bolted directly to the back of the case extension ,on an atv or go kart they install a sprocket to drive the rear axle. Also ,on the typical Honda clone engines ,the engine size is usually cast into the cylinder fin area on the top of the cylinder ,although smarter people than me look at the pad near where a shifter would be and decipher the engine numbers from there to be more precise .For what it's worth ,I have seen Zero 50 cc 4 stroke atv ,I bet your atv is at least a 70cc .
