Old 07-07-2017, 11:50 AM   #2
I wonder if these front forks could be used with the TT250 triple clamps for a budget fork upgrade on the Hawks? Buying the whole assembly from CSC would cost almost $800, because they want $300 a piece for the forks, but the entire triple clamp assembly is only $95, and if these forks would work, that could do the whole conversion for $255, and be, more or less, a bolt in conversion.
Yes, I know I could convert to some name brand bike forks, and it's tempting, but for a hassle free conversion that requires no real work, it's a step up from the toothpick forks the Hawk comes with.
Anybody with a TT250 care to measure the forks at the triple clamps? If the match these then I may just pull the trigger on ordering some parts to do this.
If you are referring to the Chinese USD forks, I believe you might be correct. You need to determine if the triple tree from the TT250 will fit the Hawk. However, you would also need to convert to the TT250/Bashan front wheel, brake rotor, brake caliper, speedometer sending unit, et cetera.
What is the fork travel for the Hawk?
