Sounds like you got a heck of a deal on what is essentially a brand new bike. If it sat that long then I would expect some small work here and there ahead of you. Definitely pull the carb and look it over. I would also be prepared to replace most of the rubber lines as well. Change the enigine oil and crank it over without fuel for a little bit to circulate the oil through the motor as well.
