Originally Posted by mcwhorter-enforcer
So my Enforcer is scheduled to be here in the morning. Only took around 7 weeks but o well.
Let's talk proper break in for the CG motor. What are the experts recommending?
This is going to be a very slow build. I will be doing exactly what was recommended by you guys previously.
1. Changing all fluids
2. Removing every bolt and nut I can find and adding loc-tite or a lock washer.
3. Adding grease to the swing arm- I could use some direction on this. Anywhere else I should pack in the grease?
I plan on riding it stock through the break in period then replacing the exhaust,air box mod, and jetting.
Front and rear axle, and the swing arm bolt or axle. Also gease the stem head bearings...ARH
