Originally Posted by timcosby
just watched your vid and when you say its gets stuck that looks like it is when you try to go to third. most of the time the bike has to be rolling a little bit to go thru the gears even when coming up on a red light and going back down thru the gears if i wait to do it while stopped some of the gears will be difficult to get to engage. what your showing in the vid may not be a problem cause its not moving up at all but i think thats because the bike is not rolling. when it does go up it looks to be hitting the case so its needs bent or rotated on the splined shaft.
It won't go into third while riding either it gets stuck exactly like in the video.
