Old 10-26-2017, 01:18 AM   #2
Musictrek   Musictrek is offline
Musictrek's Avatar
Just out of curiosity, ehat year is your Hawk? I am under the suspicion that the 2017s got an electronic relay from the factory. My flash rate didnt change after installing all 4 of mine.
mine is I think a 2013. I thought I had it figured out with installing a 6ohm resister parallel on the circuit for a left front and back led working signal. It worked then it didn't. I'm going to check my wiring. I did have it working under a test. I will be using two 6ohm resistors if this works out right.
I got it working great! After i soldered the wires up, both front and rear led lights worked like normal. They are nice and bright! I also moved all the wires from the wheel area to the cleaner and dryer location under the seat.
