Which Oil Drain Bolt
Hello H250:
I have been using the bottom plug for quick oil changes in these first few miles....For four bucks per quart at Walmart, why not. The screen does need cleaning at intervals. Either one will work as long you occasionally clean out the screen. Be sure to note how you took the screen apart for correct reassembly. Harbor Freight has an impact socket 15/16 for a few bucks...check to make sure you have the drive you want (3/8 or 1/2) on the socket. Let's recycle our oil.
