Originally Posted by Bill1
I finally installed my digital cluster for the Hawk and I am missing the 5th gear indicator. I jumpered to the new harness and the new cluster and harness work fine (When the bike is in 4th and I jumper from the 4th gear wire on the bike harness to 5th in cluster harness, the new cluster says 5th).
But when I try to jumper the 5th gear wire from the bike harness to any of the pins on the cluster harness, I get nothing.
All of the other gears and neutral work fine.
How hard is it to get to the gear indicator sending unit?
Nevermind... with everything put back together, it's now fixed.
Either the ribbon cable from the transmission to the harness was pinched by the housing and wiggling it helped, or it was just magic.
Regardless, I am good to go now.
2016 RPS Hawk 250, exhaust, Uni Filter, Mikuni VM-26 clone w/ 120 main & 30 pilot, MSR shifter, 17/45 sprockets, JT chain, digital cluster...
