Originally Posted by pcast01
I found the right O-ring size in a packet of assorted ones at Autozone and I got it back on there and I re-assembled the Carb and put it back in place. I was trying to test it out but the throttle is stuck. I figured I put the plunger back into the carb wrong so I am gonna take a look at today and fix that.
If you over-tightened the carb/intake pipe bolts it can also cause this problem....ARH
