Originally Posted by Weldangrind
If it interests you to learn the slow jet size, you can use a hillbilly method that will get you in the ballpark. If you buy a numbered drill bit index that ranges from 61-80 (generally in the $4.00 range, including shipping from China), you can find the bit that matches your slow jet and then measure the bit with a vernier caliper. Don't trust the size marking on the index; you have to actually measure it to know for sure.
A Metric measurement will be equivalent to a Mikuni jet (eg. #38 = 0.38mm). Once you know that number, you can cross-reference to a Keihin chart.
The index will come with a pin vise, which allows you to chuck the bit and drill a jet. I've drilled several slow jets that way with good results. Here's one: https://www.ebay.com/itm/17pc-Fine-T...UAAOSwR2RaJ9~m
I thought about doing that. I used to race go karts and had to drill all my own jets back-in-the-day. There is an art to doing it correct. Thanks for that link! I am going to get that set. I have lost some of mine through the years.
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
