OK Look at this picture. on example 2 and 4 the piston is making its way to TDC. But As ARH noted only in pic 2 are you on your compression stroke. note the valves in pic 2, both are closed. in 4 the Exhaust is open. so TDC happens at 2 and between 4 and 1. Hope that helps.
