Originally Posted by Megadan
Honestly, given the opinions of two others that have done 30mm carb installs now, I think that even a 32mm carb is a viable upgrade with head porting. That is definitely getting into "race" bike kind of territory, but for the ultimate in top end power it would be hard to beat.
Megadan, remember that Keihin carbs are described by the diameter of the air cleaner side while Mikuni's are described by the venturi diameter. a VM 28 is equivalent to a 32 mm Keihin. However, the Keihin shown in the link has a starting jet instead of a choke which should give improved performance above 3/4 throttle even with the 30mm model...ARH
