Originally Posted by Swollbraham
1st change oil and chain after buying. I went with a D.I.D 428 130 chain.
7th swapped my rear sliders to washers and bolts, chain seems to rub on the factory ones. (This could be an assembly problem)
8th swap chain guide.
11th in the process of tracking down black panels. If you know of where I could buy from?
Swollbraham, I had some questions about your mods:
Item 1, was the chain you bought an "o" ring chain?
Item 7, what is the rear slider you're referring to?
Item 8, What did you replace the chain guide with? Are you referring to the rubber guide on the swing arm?
Thanks.
