Old 02-08-2019, 02:37 PM   #9
glavey   glavey is offline
I did a bit of experimentation with the ebay exhaust last night and I discovered that if I flip the mid-pipe around and connect the muffler to where the header pipe would usually go and vice-versa, I can just barely clear the starter motor and rear swing arm, but I'll still have to trim or remove the passenger foot pegs. It will still be tricky making an exhaust hanger that not only holds the muffler where it needs to be vertically, but also horizontally.
I'm at the point where anything more I need to do with the bike involves me buying something. Dielectric grease, lots of different nuts/bolts/hardware for many different things, metal vacuum nipple (still makes me giggle on the inside) for the fuel pressure regulator, o2 sensor bung, water-proof connectors, crimp tool for said connectors, fork oil, FI hose and clamps, copper tape, 8/10mm taps, you get the idea. Once the ice thaws and I can make it to a hardware store, I'll get what I can. Until then and after that, we all have to play the waiting game while watching the mercury slowly rise...
Are we there yet?
