Originally Posted by Hawk'em
Hey guys i have a shift shaft leak on my Hawk but plenty of oil still in the bike. I'm having problems down shifting. It will shift up all the way through with 0 problems. Has anyone else had this issue or can anyone point me in the right direction here on what to do or what the problem is?
No issues up shift, but issues down shift, is generally a good indicator of the clutch dragging a little and the clutch needs some adjusting to get full disengagement. These bikes tend to suffer from a decent amount of clutch fade once the engine gets hot, so what might seem fine cold, is not fine once warmed up, and will either need re-adjusting at the lever once you get up to temp, and/or the clutch adjusted to what almost seems like it is nearly too tight when cold.
