Originally Posted by JerryHawk250
The PWK30 will probably better for the Apollo because you will have easier access to the idle mixture and idle speed screw being that your carb angles to the left side of the bike whereas the Hawk angles to the right side of the bike.
This is probably a big one. For the same reason I chose to go with the PE30, you would be better off with a PWK, otherwise reaching the adjustments would prove to be a pain in the rear.
Performance wise there won't be much between them, although the PWK will have slightly better throttle response due to its slide type.
