As Mudflap mentioned above, there is a center crankshaft seal, a big outer o-ring, and there are two small o-rings behind the stator plate for the mounting screws. You'll need a flywheel puller to access the stator plate, I believe it is the one shown below - M27mm x 1.0 with LH left hand thread.
