Old 09-24-2019, 01:54 PM   #2
AresROC   AresROC is offline
AresROC's Avatar
@CaesarVis I have the PZ30 and have the same fuel mixture screw. Do NOT buy the Motion Pro D-Shape carb tool from Amazon it won't fit it's too big.
I ended up buying this but NzBrake's ebay kit version is even better. I use a small flexible screwdriver extension from Harbor Freight to reach it.
The main jet you put in won't affect the idle much. Factory fuel screw setting is 2 turns out on mine. Optimal is 1~3 turns anything else to get the highest idle RPM you should change out your slow jet.
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D
JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair .
Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2
BSR Chronicles - "Project leads to more projects!"
Yamaha WR250R
Suzuki GSX-R 600
