Old 10-02-2019, 12:55 AM   #1
Whisky   Whisky is offline
Whisky's Avatar
2 Questions. How did the hf tire changers work out. Did it make a pita job considerably easier? Secondly. Will a Grom triple tree fit on these clones or to bypass the cut and welding, I'm guessing the bearings would still be a no go unless u matched up with a Grom frame, which would be a little much just for the better bearings.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
