I wanted to mention this before, now I will finally ask: Have you checked for vacuum leaks? In your signature, it says Uni Pod Filter. I always wondered if those filters could cause a crack in your intake runner rubber, as it happens to others.
So use a tissue paper going around the engine while idling, some use propane gas or even starter spray. Check all hose connections.
