Originally Posted by durtyrice
Your posts have taught me pretty much everything I know and is the reason I bought this BD 125 actually. Your post in March with the pictures is the guide I use for the carb upgrade. Thanks for that.
I don't think my spinner kit includes screws. Do you remember what size screws you used? I'm thinking M4 6mm.
Also, what do I do with the paper gasket? Do I stick it between the plastic gasket and the carb? Or should I put it between the intake pipe and engine?
my first spinner carb mount didnt come with screws and i di find some to work but never found them to be shallow enough on the head, so i had to grind the screw head down in order for them to be flush with the spinner. this setup didnt last very long so i ordered the spinner kit that used gaskets and came with good and ready screws.
i cant remember right off about the gaskets, but sometimes they send wrong size in the kits..
